Company Logo (800) 853-2651 Shop Now
B engine serial #
Jeff B.
03-14-2010 15:11:16
I see lots of info on the engine serial numbers starting with CE --- I don't have anything like that on my 42 B. All I can find on the engine is the casting numbers AM-4033-8 IS there any other serial numbers on the block? If so, where are they?
chalmersbob(pa)
03-15-2010 18:10:49
 Re: B engine serial # in reply to Jeff B., 03-14-2010 15:11:16
That has to be a later engine or from a power unit. It has the embossing for a fuel pump.
Don't know why it doesn't have a serial # in the flange. It should start with CR. Bob
Jeff Z.
03-14-2010 16:13:23
Look here to the left of the yellow mark on the engine flange.
third party image
Jeff Z.
03-14-2010 16:30:12
 Re: B engine serial # in reply to Jeff Z., 03-14-2010 16:19:31
You may have a 116 CI enngine.
The serial number will be on the back of the engine.
Jeff Z.
03-14-2010 16:55:46
 Re: B engine serial # in reply to Jeff Z., 03-14-2010 16:30:12
For a 116 CI engine the serial number should start with BE.
Look on the back of the engine below the head.
Jeff B.
03-14-2010 19:57:08
 Re: B engine serial # in reply to Jeff Z., 03-14-2010 16:55:46
My engine is on a stand, all cleaned up so it's quite easy to see. There are no numbers stamped anywhere on it. I've checked every flange & everywhere else that I can think of. Casting number is AM-4033-8 It doesn't really matter alot, I was just curious, but it strikes me as odd that there's no stamped numbers on it. Tractor is # B59917 which would make it a '42.
Jeff Z.
03-14-2010 20:17:46
 Re: B engine serial # in reply to Jeff B., 03-14-2010 19:57:08
Strange you can't find a number.
If I'm correct the B's in 1942 only came with the 116 ci BE engine.
I don't think the CE 125ci was used on the B's until 1944.
Look really close on the back of the block below the head for a number starting with BE.
The casting number codes I have do not have an 8 at the end of any year. ???????
On my chart a 1942 engine for the B should have ended with 14.
Sorry I can't give you an answer about that engine.
JMS/.MN
03-14-2010 21:36:43
 Re: B engine serial # in reply to Jeff Z., 03-14-2010 20:17:46
Don"t know, but if it was a replacement block....? Should a dealer have stamped number into it?
Jeff Z.
03-14-2010 20:31:20
If you do find a number it should fall into this group.
1942 Tractor Serial Numbers 56782-61400
1942 Engine Serial Numbers 57579 - 62280
Jeff B.
03-14-2010 21:33:54
 Re: B engine serial # in reply to Jeff Z., 03-14-2010 20:31:20
Jeff Z, Add this one to your chart. The other day I actually sanded the flanges lightly to try to find a number to no avail. Nothing on the back below the head, either. As soon as the head comes back from the machine shop the whole thing will be orange, so I guess we'll never know, lol. Thanks for your help though. I will continue to keep my eyes open for something.
Jeff B.
03-14-2010 21:35:40
 Re: B engine serial # in reply to Jeff B., 03-14-2010 21:33:54
third party image
For some reason my pic didn't post @nd try
steve(ill)
03-15-2010 15:57:22
 Re: B engine serial # in reply to Jeff B., 03-14-2010 21:35:40
Dick, i have never seen a CE motor with a A4033 casting number. Got any ideas why they changed ?????? Is there something different on that cast block as compared to the standard CE block??
Dick L
03-15-2010 09:10:11
 Could Ya Take Another Pic in reply to Jeff B., 03-14-2010 21:35:40
Could you back up and get all of that side?
DickL
03-15-2010 03:31:39
Looks like one I have out here that came off a CA that came from a military base out east some where. I'll check the number this morning (if I can get to the engine) I remember it had an odd casting number. When I removed the engine it looked like new on the inside. The manifold was in bad shape and the carburetor had been whacked around. I was told at the time that the military did not overhaul an engine that they would install a new crate short block. Not sure that the fellow knew what he was talking about and have not spent any time checking it out more.
Maybe and that is a (just maybe) a run of block castings were made as emplacement parts after the last production tractors were assembled.
Don't take that to the bank it is just a thought.
Jeff Z.
03-15-2010 07:15:03
 Re: B engine serial # in reply to DickL, 03-15-2010 03:31:39
Thanks for the info Dick.
Always something new popping up.
It never ends.
Jeff B.
03-15-2010 20:35:39
 Re: B engine serial # in reply to Jeff Z., 03-15-2010 07:15:03
third party image
Sorry, I missed that request from Dick L. for another pic. I took another one tonight. Here it is...
DickL
03-16-2010 04:58:22
 Re: B engine serial # in reply to Jeff B., 03-15-2010 20:35:39
I looked the best I could and didn't find the one I have or had. I remember the AM 40 but am not sure about the last two numbers. They started to put the arrow shaped deal on the blocks with the start of the CA production. The one I have or had I bought over 12 years ago and lost track of where it might be.
It would be a replacement block for your B in anyway regardless of what is was built for or where it came from. The bare block inside dimensions would be the same as the one that came on your B.
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership, ... [Read Article]
Latest Ad: NOS IH parts [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
