Bob Landers
I'm new to the engine overhaul business and would appreciate your experienced advice. I have the engine on a stand and intend to replace the rings. Tolerance on the rod inserts is OK, wrist pins and crankshaft seem solid. Otherwise, the engine looks pretty good, although I have no history and it wasn't running when I got it.
What I'm wondering is should I remove the crank and cam shafts to clean? Also, is it possible to clean all the oil passages without completely disassembling the engine? What else might I be missing?
Thanks for your help.
