Anonymous-0
Hi
I just bought a ca it seems to have lost 2&3 gear
are the trannys known to give trouble?Any help would be great
thanks
take the boot off from around the shifter and remove the "C" clip to pull the shifter out. look down the hole and using a long screwdriver, align the shift linkage so that all of the slot line up then return the shifter. An occassional one will jump out of gear going down hill. that's the only problem that I have run into. Bob
