Company Logo Shop Now
hydraulic B allis
tooltimejim
02-19-2010 04:39:23
I cleaned out the the discharge side of the hyd pump, I was not able to remove the valve inserts, I did get the spring/ball out, I cleaned the surfaces up the best i could, put back together, but I still have the problem of hyd dropping, will raise real nice, but soon as I release lift handle,the hydraulics drop immediately. ?? not sure what to do next. anyone have a hydraulic unit for sale, that functions good? Jim
old
02-19-2010 07:26:54
 Re: hydraulic B allis in reply to tooltimejim, 02-19-2010 04:39:23
Ah but are you sure you do not have a bad cylinder since if it has an internal leak a bad cylinder will cause the same type of problem and oh by the way it can/will drive you nuts trying to figure it out
tooltimejim
02-19-2010 14:52:34
 Re: hydraulic B allis in reply to old, 02-19-2010 07:26:54
Old, i was starting to think that it may be the cylinder causing the problem. I know the cylinder has a little leaking, always leaves drops on my garage floor, maybe I should try find a good cylinder, and try that. where can a guy find a good cylinder or what kind do others use, if not original, thanks Jim
old
02-19-2010 15:38:55
 Re: hydraulic B allis in reply to tooltimejim, 02-19-2010 14:52:34
An Agco dealer will have or be able to get all the parts you need to rebuild that cylinder. There a very simple cylinder to rebuild or take it to one and have them do it probably would not cost all that much to have them do it and if they mess up they bite the bullet on the parts
tooltimejim
02-19-2010 04:48:09
My manual also says I can flush the unit with gas or solvent without disassembly, but removed from pto housing. the manual does not tell me the proper way of flushing the hyd unit. any thoughts or suggestions on flushing the unit? thanks again,Jim
Dick L , you are right, projects are never 100% done.
Today's Featured Article - ... [Read Article]
Latest Ad: 3 JD 6600 d combines 1 w 329 1 w 404 Turbo 1w 404 non Turbo believed to be good motors also 2 JD platforms and 643 ch posting for friend call for details. [More Ads]
Copyright © 1997-2020 Yesterday's Tractor Co.
Binary file (standard input) matches
