steering gear c vs.b
dusty1771
New User
i put a wide front from a B on my C now it steers backwards how can i fix thiswith out changing gear box the one from the B is cracked
Yep that is the problem with them and just switching the front end you get a right turn when you try to go left and verse visa. I do not know that you can do any thing about ti other then find a B steering box that is good
Ralph has it. To prove it out hold a pencil in the center and move it back and fourth like your gear box steering arm is now and you can see that it will push or pull the steering link the opposite direction from the top to the bottom. Problem being the old steering link will have to be altered and not look any where correct. That is why most will buy a B steering box to replace the C steering box.
Never tried this but it's a thought. If the steering gears are the same brand, maybe you could switch the screw. I just don't know if there are any other differences amongst the same brand box other than one is obviously a left thread and one is right. There were different brand steering gears used so beware.
Good question Bob. I have several Gemmer steering boxes for C's in the shop and several Ross steering boxes for B's out there also. I have one Ross for a C that I rebuild here at the house but did not compare the parts when I had them apart. I have a C at the other place that I think has a Ross box but I will not get out here to mess with for quite some time. It won't help now but when I get to it some year I will remember and take pictures.
The Gemmer and Ross boxes are very different.
