D17 Starter nose broke
Broke starter nose on my D17 gas series III. It was a clean break. Has anyone ever welded these? If not does anyone know where I can get a nose?
I checked the engine and it turns over ok. I had noticed that the tractor turned over slow of late so it may have been broken for awhile.
Any help is appreciated
It can be welded in an emergency but you have to be careful to get it welded back together straight. I welded the nose cone off a 2 cyl Deere starter just to get by until the replacement came. The 'just to get by' period lasted five years or so until I finally got ambitious and put the new one on. Used Nickle rod and peened between every pass. Jim
When you DO find another nose, check ALL the flywheel ring gear teeth and the base timing AND the centrifugal advance.
It very likely broke for a REASON as will the replacement, if you don't find the cause and repair it.
