I600 vs. D17
ACNY Wayne
New User
Which tractor, in like condition and equipment, would be more valuable?
Suposedly the I600 is heavier built but a little less on the horsepower and weight.
The I600 is also rarer, don't know what that means value wise, I believe the D17 was the most popular AC built.
br>Thanks
I600 was the construction/industrial version of the D15 series 2. Condition being equal price of the I600 will likely be higher than a D17.
Dave,
That's what I thought. Would the shuttle clutch be an asset or more of a problem? Haven't seen too many for sale.
Thanks,
Wayne
Steve, the one I looked at was rough--rough. Beginner patch welds on the loader, seat was raised on two 1" thick plates of steel (might have some value here); it needed a carb, Loader valves, fenders, half of the hood, gauges, sidepanels, tires, etc., and probably a motor rebuild. I only did a walk around. He wanted $3K, I considered offering $1K but didn't think it was worth it. Looks like a money pit to me. My question here is for future I600's. It seemed to me that since AC didn't make that many of these that they might have a better value. I'll be glad to send his contact info to you if you want it, I can't handle this one. Your reply was funny, you were probably joking but just in case....
I have only seen one shuttle clutch, in my travels. They are definitely rare, at least around here. They use a handle, on the left side, similar to the power director clutch, I assume some of the clutch parts will interchange. If it works, its an asset, if not... maybe not.
Dave,
This shuttle clutch works on a foot pedal that is pivoted in the middle: ie. toe and heel. I think it works, didn't see the tractor move. Probably could "restore" with paint and parts for around 2000. It has an AC loader, like a 460. Front mounted pump works.Control valves are shot. Anything major would make this a loser.
The shuttle clutch and the PD clutch assemblies are the same.
What makes it into a "shuttle" is the reversing gear set ahead of the PD.
Never seen a foot petal one, probably wouldn't be hard to rig. Might be oem in a newer forklift, The one that I have seen was a hand lever on a series II tractor/loader. Does this one have round tin, or square. Could be a 500 or 600 series f-lift, see page 284, Swinford's construction book.
Dave, my book must be different, pp.284 in my book is about harvesters. My Swinford has the I600 on pp 206? Anyway, the one I saw was a square grill/hood. Maybe I can get the owner to send me some pictures.
WM.
Duh, I never thought about that. :)
Thought maybe I had the wrong book.
Anyways, it sounds like a good I600 might be a desirable tractor if its in good shape.
Thanks
