Bill's Tune and Till
New User
I have a WD, 1948 model. The two point hyrdraulic will not descend for me when I pull the lever down. I can unhook the right cylinder (facing the rear of the tractor) and the left cylinder will descend. Both hoses attach into the hold positioning valve mounted on top of the pump. Right hose goes into right side of valve and left hose goes on the left side but behind the drain plug so the hoses are not lined up when attached to the positioning valve. I have reviewed the manual and adjusted everything I can but still cannot get the hitch to descend. I have tried two different cylinders on the right side with the same results. Anyone an expert on these hydraulic systems?
