I put a WD45 engine on a C and am having problems with the clutch.
Yes, I know the engine has a lot more horsepower than the transmission is rated for. Or the engine was designed for a frame and the C is frameless. I did it because I got the WD45 engine cheap and the C had the crakes between cylinders and sunk in the middle and thought I’d try this before having the engine milled.
I had the C flywheel milled to fit the WD45 engine and the engine is securely bolted to the frame. Where the flywheel mounts to the WD45 crankshaft sticks out farther that the C. I’m using the C clutch and drive shaft, which was working. I’ve adjusted the release fingers four different positions. Engaging the PTO does not work.
What could be the problem?
Thanks
Thanks
