Wd 45 snap coupler bell spring
It appears that the spring or springs in the bell of my tractor are worn out or broken. Any trick to getting these out? It appears that the shaft is froze in the the latch. The only thing I can think of is heat and patience.
You could unbolt the entire assembly and push it apart in a press, but I"d try a good penetrant and heat before that. Spring is a one-piece.
