Allis 190XT pops out of 3rd
Anonymous-0
Greetings,
I have a 190XT that has been a splendid tractor for me for nearly 20 years. Unfortunately it has started popping out of 3rd gear under load.
From this group I know this is a common problem.
What is the best fix?
What is the best remediation for today?
take care
Look back thru posts here. Some have had good luck just by pulling the cover and working on the detent. Some have made a lock to hold shifter in place. Worth a try before splitting and putting lots of money in, but if you do make sure to do all updates.
Its funny it pops out under a load,usually its all on the down hill ;they can usually be fixed like someone else said, with the indents and shifter rail adjustment, Dr Allis says to put a heavier spring in there ; it helps alot, just getting the gears to engauge better is the key; AC shoulda fixed this at the factory, people got killed on these dam things cause of this,
