WD45 Char-Lynn power steering
#1: The installation manual says to bend a 1/2 inch offset in the throttle rod to clear steering body. Won"t this make the rod too short to go back where it came from?
#2: How hard would it be to find a replacement double groove pulley for the crankshaft?
Thanks.
Mine setup came with the bend in the rod and I know someone with a double groove pulley that might part with.Email is open.
Vito
Hi Orangepower, When I installed my unit I used a piece of same size rod and bent it in the press.
I then cut the origonal rod and welded the piece
in to make the correct length. By bending it in the press it was easy to make a professional looking job. Still working after 40 years.
Good luck, John
