tooltimejim
After I made sure crank gear "-" mark and cam gear mark matched, and the "o" mark on cam gear to governor gear matched, I find im exactly 180 off. I looked at pictures of the tractor plug wires I took before I tore engine down. If I did this right: I brought engine to TDC ON #1 , looked in hole on left side , and "center" was in window, I then installed distributor ,I installed plug wires 1,2 4 3,clockwise, It STARTED RIGHT UP,SOUNDS GOOD. But when I look at the pictures of before I tore engine down, The plug wire #1 I have now is located what used to be plug wire #4 in the pictures I took before tear down of engine/. thanks Jim
