allis B clutch release bearing question
I got a new allis B throw out bearing, and it fits over the bearing carriage with firm pressure,by hand.I was thinking about that a bit, I know when I took the old one off I had tap it off with a hammer. should it be more of a snug fit, or does it sound like the right fit/ THANKS, Jim
The bearing should fit on the collar with a light press fit. If it just slides on it may be too loose. Look for indications of it having possibly spun on the collar from being seized up. If you can tighten the fit up a bit it would be better.
Slip the bearing off and slide the collar over a solid round bar,use a sharp center punch and hammer in about a dozen places around the collar,press the bearing on and you are good to go.
