throttle adj. WD-45
I need help with adjustment at the long and short rod at the bell crank.set the long rod to get correct high rpm"s, lever will not go all the way to low rpm"s position. set to where lever is in correct low rpm" position high rpm.s go to high. i am not sure how to correct the problem. is it possible i have the wrong bell crank?
i beleive the small rod on the bell crank that moves up and down is whats keeping youre hand throttle from moving its full range.
