combine 60 have same engine as a AC B?
Same engine. Same head. No more horsepower in a tractor. You wouldn't know for sure of the horsepower until you knew what size pistons were in it now.
the 60 should have had a B-125 power unit in it. It runs at 1900 rpm when on the combine. You will note that the govenor spring is shorter then on the B tractor engine. I have one on a CA and it runs down the road a lot faster then a normal CA.
Bob
