front mount pump d 17
i want to mount a pump on my series 1 d17 i have the right pulley on the crank shaft but i don't know what pump i need to get anyway any feed back would be helpful
Check the front side of the pulley- if it is machined flat and drilled and tapped with two holes, you can add a pump in front of the radiator, and it connects to the pulley with a shaft through the crank hole.
