Kevin Larkey
New User
Can any help with Hdy . to stop 2 point arms and a single cly. with lifting at the same time! Have turned control valve to shut off two point ,but still wants to lift them .We are mounting a 190 corn picker to it and having troubles. Or can call me at 815-878-2524 or 815-878-8357 Thank you!
That control valve at the rear is a transport valve- it does not shut off, it just controls how much oil flows through it. Meant to be used with pull-type implements, when screwed counter-clockwise. Turn it clockwise, and tie the arms up if you want to use the remote valve without waiting for the arms to raise when lifting the picker.
No. If it was a WD, you could unhook the hoses and plug the lines, or put in a high pressure ball valve in each line, but the D17 has an internal hose feeding the lift cylinder, from where the transport valve mounts. I suppose you could remove the snap rings and pull the arms off.
My dad ran a 190 picker on a Series III. You can't take the arms off because the rear mainframe mounts to them. Dad did not have a transport valve on his Series III, he had more of a home-made plumbing arrangement and he just disconnected the internal lift cylinder and only the remote ram was hooked up when he had the picker mounted.
I looked in my 190 picker operators manual last night briefly and did not see a good explanation of what to do here in the manual. Mike
Yes Mr. Shy high you are rite so far as to what we have to do . We have it all mounted and you do have to use the 2 point arms . So we are going to have to do a little creative plumbing to make it work! But thank you all for your advice!!!
