Hi All,
I'm a newbie to tractor world, working on my second AC, a D 17 Series I. My first was a D12. The D17 had no oil pressure when I got it but everything sounded fine and ran great so I figured it was the gauge. After hours of research in the archives here and some excellent advice here's what I found: The oil pressure problem was in the oil filter. The previous owner thought the wooden dowel was supposed to stay in the filter--it was still there. He owned this tractor for 20 years! Sounds like he threw away new unused filters for twenty years. I made a new steel tube from a 1/4" brake line, haven't tried it yet because everything is taped up for painting. The new tube has a little less resistance than the oem tube because it has a slightly larger id.
My question is, what happened to the filtering/lubrication process while the wooden dowell was in the filter?
Does the bypass mean that the oil was pumped though the engine and not the filter? I believe I read that only 15% of the oil was filtered.
I am using Purolator 30007 filters.
So did my engine suffer damage from not being filtered?
Thanks,
Wayne
Thanks,
Wayne
