Finally got back to the WD. Was going to rehook up the starter and I thought I'd check the wiring on the old girl.Looking at the ammeter I see I have three wires hooked to the discharge side, Ignition, lite switch, and one, I believe going to the generator. The other side of the ammeter, the plus side, has the wire to the starter. Is this correct, or are the wires reversed? The starter has never worked right since I got the tractor. First I thought the generator wasn't keeping up the battery, and then I thought the starter was bad. Could it be the wiring all this time? I've had to recharge the batt damn near every time I've used the tractor.
