WC steel rear?
It"s a puller. runs out of motor. 14.9/38"s might have something to do with it!!!
Didn"t know if an "RC" ring and pinion would go into the stamped steel rear end.
It"s a stock puller, on rubber tires. I have a stamped steel rear end I want to install, to save some weight, just wanted to re-ratio the rear end to slow it down.
i had a 1935 unstyled wc and a 1945 wc with the steel rear and they both weighed pretty much the same as far as weight. i dont think there is much difference in the weight.
I think the carriers are the same. Just different housings. I'll bet the steel housing is good for a couple of hundred lbs. I'm glad it's you buying 38" rubber, and not me!
RC REAR GEARS will work slows it down about right for big rubber will bolt right in need to use wc carrier with 4 spider gears rc carrier just had to gears will break if put under strain found that out the hard way ,chipped tooth off of high dollar rc gear i welded new tooth on still running after five years of pulling with 60 horse motor
