D 14 slight backfiring
I have a d14 that I think is backfiring slightly. I just rebuilt the carb to correct it but it didn"t help. It does it throughout the entire rpm range. It takes several seconds to do it ( like 5 or 6 seconds and then it pops a little through the carb. Any Idea what that could be?
I timed it. It was ok. I ended up looking at valve timing and found a rocker arm adjustment screw fell out, so the valve was floating. I adjusted all the valves, rechecked timing and now it runs nicely.
Thank you for all your help.
