C steeering rod grease cups
02XLT4X4
I need the rubber cup/boot things that go on the steering rod that runs beside the engine on a ’47 C with narrow front. Anyone have the part numbers or a different application that will cross over?
The last time that I replaced these, I picked up a couple Ford automobile tie rod ends - ones that had grease fittings. I then cut off the old ones and welded in the tie rod ends - being careful to make it the same length. It worked great and I think cost about $20.
I thought about doing that to fix the rod that is on the tractor now, but my parts tractor that was only used to run a water pump until it ran out of oil has perfect joints on it minus the rubber seals, so I was trying to keep it all sort of original and just replace the rubber seals if I can.
