WC - Spring for carb.????
Tom R.S.
I had a spring dangling off the carb throttle shaft when I got this tractor.
Its a light weight spring about 3/4 inch coil dia. and overall about 4 inches long.
Can anyone tell me where the other end attached to and what this is for?
My WC is a 1937.
Thanks
That is a different spring. Vertical spring between throttle rod and water drain is used on some tractors, not all- to prevent surging.
