AC pull type combine on craigslist?
Alan K
I think there is an AC combine for sale on craigslist.com ( Minneapolis MN listings - Askov MN ) Model 66 all crop I think. Im not sure how to post links on here but the phone no. is 320-838-1563
It may not be a 66. The unloading auger is on the front of the grain bin, not the side. 60 had the auger in front, but I"m not positive that the very first 66 models also had it there. Either way, likely to be from the early 50s. Looks pretty nice on the outside for that age.
That is not a 66. It is a 60, not even a 60A. The side auger came out with the Big Bin 66 which had a 25 bushel bin replacing the traditional 15 bushel.
Am I blind where's the pto shaft? I do believe that is a 60. Checkout BradK's post on the combine forum picking up a cherry 66 around 8/28.
First, open the page that has the ad on it, you will note that the address line at the top of your page (starts with "http://etc...." Put your cursor at the end of the line and highlight the address, then right-click and select 'copy'.
Now go to the forum and get ready to 'post a message' or 'reply', you will notice that there is "Optional Link URL:". Put your cursor on the left of this box and right-click again; then select 'Paste', and the address from the first page will be put in the box.
You can then type in a description in the box marked 'Link Title' and you should be done.
The first one is the toughest...
