Allis Chalmers generator
JM976
New User
Working on a D17 gas engine and I need to know if the generator is internally grounded or externally grounded so I can correctly polarize it. Were these Delco-Remy? I"d sure appreciate any info...tractor #76284,series IV,1964
Im pretty sure AC used a Class A Charging System. They have one brush internally grounded BUT THE FIELD WINDINGS ARE NOTTTTTTTT internally grounded as on a Class B system like some Fords used. The one Field winding end attaches to the same point as the Armature post while its other end terminates out the gennys FLD post (isolated n insulated from case). Therefore to Polarize the genny you can momentarily flash jump a wire from the BAT terminal on the VR over to the ARM/GEN terminal. Or else direct (jump a hot ungrounded battery voltage source) to the gennys ARM post accomplishes the same thing.
John T
John T,Texas Denny,many thanks to you fellas for your info and quick replies, lucky for me I found this forum and the help I got from the people in it. With that and a little luck hope to add another D-17 to the active list!
