Anonymous-0
I have a D14. It does go through a lot of points. It has been converted to 12V.My question does it need a reducer from (12-6) will that help the points last..Or the heck with that and switch it to Electronic ignition. Pro Cons Thanks
Yes, It should have a ballast resistor in the ignition line to the coil.
The other way is to get a coil with 3ohm internal resitance like the one in the link.
John at the Brillman Company and Steve at B&B can supply you one.
John:1-888-274-5562
Steve: [email protected]
You can also try NAPA
Coil
If you are using negative ground,the negative side of the coil needs to go to the points or it will burn them out prematurely.
