ca starter drive
If you have the started off the tractor and the end cone off then take the bolt out of the spring and slide it off.
thank you. there are 2 bolts on the spring and since both look the same, i thought they were just holding the spring
That is the reason to ask questions. Next time you won't have to ask you will be an expert. As long as you don't loose a washer.:)^D
