Allis Chalmers D17 Governor
W M
Hi,
My throttle was all over the place and after reading the posts here about ruining the timing gear, I removed and checked the weights and pins on my D17 governor, everything was fine, like new. But now I can't get the governor back in. After 2 hrs, I don't know why I can't get the gears to mesh, I am pretty sure I am keeping the weights closed. Hope you can help.
Thanks,
Wayne
PS: I marked the distributor position very well, understanding that that is only for timing and I will have to retime the engine. The gears in the governor have been rotated freely so they will have to mesh with the cam gear. That is where I bumped the starter once and chickened out. Afraid that I might chip a tooth as it probably wasn't in. I tried to turn the main gear with the distributor shaft to help it mesh but wasn't able to get it in. That's as far as I went before seeking experienced help. That took about two hours. And it gets heavy and frustrating so I thought I'd better stop.
Now it's in place, but still about 1/4" away from seating. The parts book shows some kind of a slot at the distributor end of the main shaft that might be used to turn the gear. It would be accessible through the large cap plug at the Dist end of the shaft. Do you agree? I am afraid to bump the starter for fear of chipping a tooth.
Mitchell,
Thanks for your response, I finally got it today, first I measured the depth to the cam gear to make sure I was partly engaged with the pump gear, then I bumped the starter and it went right in. PS. I did check the cam gear for broken teeth before putting it back in. Now I am back to getting it adjusted correctly. Hope that does it.
