Fan Shaft and bearings
One of my bearing went on my Model G fan cooling system. I took it to a tractor repair garage because the fan and pulley is press fitted on. The repair center did not have the faintess Idea how to do this job and pulled the shaft and bearing all apart and when I went to pick it up, the fan was put on the shaft too far and all the measurement are all off for the location of the bearing. Does anybody have the measurement of the exact dimension for the bearing on the drive shaft. Or I would Like to get a whole new Fan and shaft.
Brent, The fan shaft bearing nearest to the drive pulley is #800421. The bearing on the fan end is 800420. I have used bearing #MRC488016 and bearing #MRC488503 respectively from Motion Industries or any bearing supplier.
No, This on a G without a water pump and the radiator is at the back of the engine. the fan shaft runs across the top of the engine with a
pulley on 1end and the fan on the other. Bob
