OK I'm stuck here. I have a .020 ground crank main and rod, bought new .020 rod and main bearing but am still having problems getting thim to turn. Jurnels are round within .0005
Main are plastic gauge at .002 clearan and I can turn the crank by hand with some resistance.
Rods have .0015 to .002 clearance as the plastic gauge says but when I toqrue the rods down it gets tight and at 90 degrees it seems to bind.
After rod 1 and 4 were put in I was still able to rotate the crank but seems to get stuck at 90 degrees.
Help what am I doing wrong. Thanks
Frank
Frank
