Carb identification
A lot of times you have to pull the carb off to read the tag in it since the tag is on the inside when one the engine. Should have a small tag riveted on it with the numbers
Depending on the make, model and size of the carb, the ID tags will vary. On Zenith small and some large bore carbs, there should be a little round disc riveted to the fuel bowl with two sets of numbers on it. The number closest to the outside of the disc is the AC number ie-212845 and the inside number will be the Zenith number ie-9707. The small bore Marvel Shebler carbs have the same setup as the Zeniths with the tag riveted to the bowl. A lot of your larger bore M/S carbs will have a square tag under the mounting flange of the carb. The number of the carbs usually start out with "TSX"-xxx with three digit afterward. ie-TSX464 If you need a carb kit we can help ya out. HTH
Steve@B&B
Here is a page from the WD45 Operators Manual.
<a href="http://s239.photobucket.com/albums/ff293/ovenstu/?action=view&current=WD45Carb.jpg" target="_blank">
WD45Carb.jpg" border="0" alt="WD45 Carb
</a>
Marvel Schebler / Zenith catalog lists these for the WD-45. Marvel Schebler cast iron, TSX-464, TSX-773, TSX-871, TSX-561 which all use the same kit Zenith part number K7515. A later Zenith replacement would have aluminum body possibly carb no. 14991 which uses Zenith kit no. K2127. Should be able to get a aftermarket kit with those carb numbers also.
