WD Engine weight
Wulfdog
Anyone know how much a WD engine weights out of the tractor? Curious as I hauled one through my house on a wagon and nearly killed me and the wagon. Not to mention a lot of creaking. Thanks John
Some where around 300lbs give or take a few depending in what all you still had bolted on like the flywheels etc.
It has everything just like it was pulled out of a running tractor. Crank pully back to the flywheel and clutch. I sure thought it was heavier than 300 as my wagon is rated at 800lbs and it nearly destroyed it. I was warping bending and creaking. I weight 450 and use a 50lb wheelchair and the floor doesn't creak and buckle under me like it did under that motor and wagon. Matter of fact the house doesn't make any sounds under me. I have solid tires and the wagon has pneumatic. John
Well I got that weight from a catalog as shipping weight for a WD engine long block so yep what you have is a bit more
