Rusty Smith
New User
I got a 1948 C model tractor from a guy by a trade, it was not running, he said that it was running a couple months ago and quit, he replaced the points in the magneto, and could not get it to run.it was sparking. I figured it was a rotor timing issue, and got some advice from "old" on here, I put it in time and did get it to run, not great but it ran. It seems to have carb issues too. My question is this, can it still not be in time? will it either not run if the timing is off, or will it run poorly?, there is no back firing, just absolutely no throttle response, and sputtering, it finally stalled out, I had put a lot of carb cleaner in it, and let it run for a few minutes, I pulled a spark plug out and it was soaked with gas, pulled a second one, same thing. I did get it to run once for having to time it, so I can do it again if need be, but with the carb problem also I don't want to overlook a timing issue.
