Fella"s, On my wd45 when I purchased it the tractor had no gov. response and it would run at what seemed a high rpm. After some research on this sight an lookin over an A.C. book I found that someone had messed with the cross-shaft and had bent it for more rpm"s. Well I re-adjusted the cross-shaft to the recommended specs and the gov. started workin great. Now the problem is that after runnin it in the higher gears I now do not have enough rpm"s at the higher end....My question is do I need to readjust the cross-shaft arm again or as I suspect do I need to look at the linkage?? I know there a couple diff. places to adjust this linkage, is one for idle an one for more throttle?? Thanks for any help. Hoss
