I went over last nite and brought home this tractor. Thank you much for your help on this one. It's in better shape than I remembered and actually ran pretty well for having sat since last fall.
I'm going to clean/rebuild the carb as my first project and I know I need an IT manual but help me cheat a bit here.........
- What is the small needle adjustment at the base of the bowl? That's where the drain plug was on my model C carb but this little fellow is an adjustment. What is a good starting point on this needle?
- And above that on a 45 degree angle is what I know as an air adjustment (again from my model C carb) Is this also true on the WC? And again, what is a good starting point for this adjustment?
- Now; what is this little "secondary" transmission behind the primary transmission? All it seems to do is engage/disengage the rear wheels from the drive train. Is this for work on the belt?
Alright that's enough for now.......Thank you for all your help.....and man am I glad I bought this tractor. I'd forgotten how much I enjoyed owning my other ones.
Bruce
Bruce
