Anonymous-0
I've got my WD-45 broke down into sub-assemblies and getting ready to replace all the seals and gaskets. I've tried to get the sheet metal caps off the inside of the final drives with no luck and I'm afraid I'm going to destroy them getting them off. The two questions I have are can you still get new caps, in case I destroy them, and, do the axles usually slide out of the bull gears easily or are they a press fit? If they are a press fit or froze in place, I'm worried about cracking the casting if I use a press to get them out. I'm sure someone on here has done this before so I thought I'd get some input first. Thanks for the help.
