WD or WD45?
Anonymous-0
I just bought a WD or WD45 and not sure what the difference is and how to tell. Never owned a Allis Chalmers before. The serial number is "WD 231580 GA". Would like to find out the year too if anybody could help
THANKS!!!!
A true WD45 will have a curved shifter and not bolt on plate on the right side of the engine. A WD will have a bolt on plate on the right side of the engine and most have a straight shifter. Of course you can also have a mutt since both engines will fit in either tractor
Hobby farm
That sounds like the engine number, not the tractor number.
The only thing that is odd is the 'GA'..WD engines on a WD had either 'PA' or 'KA' as a suffix.
Might be a power unit engine.
The WD-45 engine started with '45 XXXXXXX'
The tractor serial number is on the left side rear end housing.
A WD will have one line coming from the bottom of the oil filter housing. The WD45 will have a tee in the bottom of the housing with two lines.
<a href="http://s265.photobucket.com/albums/ii205/zebra123_1/?action=view&current=Picture009.jpg" target="_blank">
Picture009.jpg" border="0" alt="Photobucket
</a>
WD45 starts at serial number 146607. Number is on the left rear vertical face of the differential. Starts with WD.
