Rob Klepinger
New User
My dad has my 47 B with a 5' woods mower on it. About 2 years ago I had a mechanic friend of mine rebuild the engine, new sleeves pistons etc. valve job, new used block, valve job, and I even had a new coil put in the mag. It has done a real good job for the past 2 years and I'm at a loss, what could be going wrong? I pulled the plugs and they all looked good, It has a miss and when you turn the mower on after it warms up it will hardly run at all if there's any kind of load on the engine. I messed with the carb screw and choke setting that didn't help.
My first guess would of been that the coil was bad, you know when they get hot they don't work as well... but like I said its only 2 years old and I am not very good with taking apart the fairbanks mag and putting it all back together correctly, my mechanic friend moved away and I'm kinda at a loss... any suggestions are welcome!
Thanks!
Rob
Thanks!
Rob
