Allis Chalmers G again!!!!
Several of the head bolts screw down in to the water jacket. Most likely they have rusted or corroded enough to allow water to pass
Thanks I did that still had small seep just tefloned the threads on head bolt problem solved. One other issue is with breather hose hooked up governor surges . I have come to the conclusion that it needs more air on carburetor adjustments please correct me if I am wrong !!!
Dustin IL
Have you taken off the a/f and cleaned it REAL good? most tend to be caked with 50+ years of oil and dirt. It may simply not be able to breath
