WD45 Engine
chuck craig in
03-11-2009 16:34:47
wanted and needed for my "D" model A/C Road Grader an engine that will fit in the space with little or no modification. Preferably the WD45 A/C engine or Maybe there is a near fit replacement in a later engine. It is a gasser. THANX in advance CC
Santiago Martinez
03-12-2009 14:44:42
 Re: WD45 Engine in reply to chuck craig in sunny soca, 03-11-2009 16:34:47
how do you find out the year of mfr on a model D motor grader? looked in the book but no notation for a model d Motor grader. mine is 6576. Where do i loook?
03-12-2009 07:45:02
THANKS for the INFO. I should be able to increase my options. CC
JMS/.MN
03-12-2009 09:15:53
 Re: WD45 Engine in reply to chuck craig in sunny soca, 03-12-2009 07:45:02
201 (fewer hp) and 226 were also used as power units. Check on gravel conveyors, carnivals, etc.
03-12-2009 09:49:34
 Re: WD45 Engine in reply to JMS/.MN, 03-12-2009 09:15:53
thanks again more info means more options CC
Kip-Utah
03-11-2009 20:30:13
You can use the 201 out of a WC or WD or any 226 out of a WD45, D17, or 170 gassers. Gleaner E combines are also a good source of a D17 type engine.
