C governor
Robert D R
02-23-2009 18:48:45
the tube coming out of the top where the linkage pivots and the oil tube connects is very loose--what is the fix for that or does it matter? Thanks
Ralph 1111
02-25-2009 21:28:34
 Re: C governor in reply to Robert D R, 02-23-2009 18:48:45
HI JK
I got out and checker my tractors today and the 1941 does not have oil line going to governor but the 1942 does so i guess they weren't used in 1941 or may have changed in mid year
Ralph in Iowa
jk
02-24-2009 11:44:07
My C doesn't have the oil line going in the top, any thoughts on why is doesn't? it seems to be "orginal" but i really don't know if it is. jk
Ralph 1111
02-25-2009 11:10:00
 Re: C governor in reply to jk, 02-24-2009 11:44:07
I think the early years didn't have the oil line to the governor
Ralph in Iowa
Jeff, Z.
02-23-2009 20:06:54
I put the word out for a cover with a tight oil tube. Got quick responses.
Call Bill Deppe (563) 652 2949 He has several governor covers with press fit or screw in type oil tubes.
yes i have one terry 319 475 2369
Hope this helps you out.
Jeff, Z.
02-23-2009 19:13:47
I would not worry about it too much. As long as the fitting on the oil line is tight it can't fall in. I bent a small piece of roofing flashing to shim it. Put a bend on the top of the flashing so it can't fall into the hole. Tap tube in tight . Don't tap it in too far.
Keep an eye on ebay for a cover with a tight fitting tube.
I just bought one for my C for $10.00 on ebay.
DickL
02-23-2009 19:08:14
If they are not to sloppy loctite will hold them in place. I have had a couple that I just put a different cover on that was not wore out.
