wd-45 serial numbers
introuble
02-18-2009 19:18:50
Hi all, just bouhgt my first wd-45 and paid $1000.00 for her . Need some help to decipher the numders.
Right side of engine block AM38-53-10
Left side of engine block 1-30-F
"" "" "" "" "" 45-77934-G ( the 9 could be an 8 )
old
02-18-2009 21:44:45
 Re: wd-45 serial numbers in reply to introuble, 02-18-2009 19:18:50
Serial number is on the left rear end side just under the brake cover. If you lay your left hand on the left tire and your right hand on the seat and look down you will see a flat spot and that is where the number is
Tramway Guy
02-18-2009 19:35:28
The 45-77934-G confirms that it is a WD-45 engine built to run on gasoline. But the tractor serial number would more useful for determining the actual age of the unit. That is on the back of the differential housing near the left brake.
