Karl F
farmerwannabe
01-17-2009 05:59:27
Hi Karl. In a post from the 15th you mentioned the distributor set up on our WD was from IH...did someone adapt one from a Farmall to this tractor?
karl f
01-18-2009 12:05:43
 Re: Karl F in reply to farmerwannabe, 01-17-2009 05:59:27
it would appear that it was adapted from a farmall. Also your cap does not look like it is fitting properly.
50s and earlier farmalls and allises were based on engine designs from the mid to late 30s utilizing magnetos. So to save costs, when distributors became an option, the manufacturers made distributors and mounts that would bolt in place of a magneto. Both the WD and farmall magnetos have the same mounting flange. Magneto mounting was pretty standardized according to my book "how to restore tractor magnetos."
Magnetos were somehow thought of as sealed magic boxes, so when any type of failure was encountered, they were pitched and a distributor was added, as the cost was far less than a new mag.--the farmer assumed the whole thing was to blame, when for a few dollars it was likely points and condensor. There probably was some marketing done to push the magneto scrappage.
The delco distributors were a popular conversion on both allis and farmall. Delco likely was offered by allis itself, as their new tractors came with delco distributors. IH had their own, so you had options there.
Someone must have decided to use an ih distributor on yours, because it will fit. yours is the second i've seen in the last 18 months, second i've seen in my life, though.
The adaptor between the distributor and mag mount flange is definitely IH, the distributor could be another make, as there were some other companies making distributors for IH towards the end. If you can see some numbers on the distributor it would help ID it.
I cannot answer the question of whether to keep it that way or not, I just know that it will bolt up, and that you have IH parts on your tractor.
karl f
ps email is open
mlpankey
01-17-2009 11:14:44
i am not karl but i was wondering about the distributor for all the allis dist. i have seen the cap is upright
JMS/.MN
01-17-2009 14:44:45
 Re: Karl F in reply to mlpankey, 01-17-2009 11:14:44
Lag angle is also different- so you can set them up to start ok or run ok, but not both.
JMS/.MN
01-17-2009 14:46:41
 Re: Karl F in reply to JMS/.MN, 01-17-2009 14:44:45
Oops= I meant a magneto! Don"t know about an interchange of distributors.
