oil leak
Leonard Dacus
01-16-2009 17:18:06
I have A D-17 Allis Chalmers series 4 that is leaking oil at the Lever that engages PTO. Can that be repaired without spliting Tractor. Any help would be appreciated.
thanks L.D.
Ed pap
01-16-2009 19:24:31
 Re: oil leak in reply to Leonard Dacus, 01-16-2009 17:18:06
Hello,
There is a oring on the shifter shaft. there is a cover on the other side of housing if you had small arms and drive out the roll pin on the shifter fork you could change the oring. I don't think I would try it with out some good magnets and alot of patience.
Good Luck Ed
