WD-45 Question
Leonard Dacus
01-02-2009 11:58:26
Need to know the length of rod from governor arm to carburetor, Think I have one that has been modified
Thanks L.D.
Bob Bancroft
01-02-2009 16:53:35
 Re: WD-45 Question in reply to Leonard Dacus, 01-02-2009 11:58:26
The correct length is whatever it takes to fit in there with the governor and the carb. throttle plate/shaft wide open-assuming everything else is in order. Ideally when the governor snaps open, the carb. shaft lever does NOT jam into the stop, it just lightly touches it.
jd2wd
01-02-2009 13:11:00
mine is about 11 3/4"
