Company Logo (800) 853-2651 Shop Now
ADJUSTING REAR WHEELS ON CA
gatwood22
11-21-2008 04:21:47
ANY HINTS ON HOW TO ADJUST THE REAR WHEELS ON MY ALLIS CA. THE SQUARE BOLTS FOR LACK OF A BETTER WORD ARE STUCK.
GAT
Brian Jasper co. Ia
11-21-2008 05:09:42
 Re: ADJUSTING REAR WHEELS ON CA in reply to gatwood22, 11-21-2008 04:21:47
Went through this on my CA. Take the wheel off and lay it flat. Take the bolts off the center that attach the 4 sliders to the center. One good whack with a sledge will make it come apart. Dissassemble the wedge bolts, remove the rust, put back together with antiseize.
gatwood22
11-21-2008 05:23:45
 Re: ADJUSTING REAR WHEELS ON CA in reply to Brian Jasper co. Ia, 11-21-2008 05:09:42
THE BOLTS I AM TO REMOVE, YOU ARE REFERING TO THE 8 BOLTS 2 PER SLIDER CORRECT? AFTER THOSE HAVE BEEN REMOVED (WHICH BY THE WAY LOSSENED UP NICLY) WHAT AM I WHACKING WITH THE SLEDGE?
Don Dittmar
11-21-2008 12:26:47
 Re: ADJUSTING REAR WHEELS ON CA in reply to gatwood22, 11-21-2008 05:23:45
The Center Piece. That will fall to the ground along with the wedges. Once they are out you can clean them up, heat them to free them, then reassemble
