2 questions on 7060, hyd filter and PTO seals.
aberenz
11-07-2008 18:22:52
First question is, does the 7060 have a "spin-on" Hyd. filter separate from the "cartrige" type trans filter? My parts guy had a listing for it but I can't find it on the tractor! Second Question, could someone tell me how to go about changing both the large and small PTO seals? It does have the 540/1000 rpm PTO. Do I have to drain the hyd fluid? Does the PTO slide/pull out of the back once you take out the bolts in the plate behind the drive flange?
cadet trooper
11-09-2008 16:10:38
 Re: 2 questions on 7060, hyd filter and PTO seals. in reply to aberenz, 11-07-2008 18:22:52
It might help if you call your local AGCO dealer and get an ID and a password to go to www.agcopartsbook.com and you will get exploded views of your tractor it really is a great tool plus an I&T shop manual has helped me a lot. CT
856 puller
11-08-2008 16:38:16
there is a filter under the front on some i think for the power director and a cartrage type in the back for a powershift. the pto seals are tricky i cant remember for sure but the oil has to be drained. there is a plate under the pto geartrain. there is 2 seals a hollow shaft and some gears to deal with. if i remember right it is easy to wreck the new seal if everything is not held right on assembly.
aberenz
11-09-2008 06:04:39
 Re: 2 questions on 7060, hyd filter and PTO seals. in reply to 856 puller, 11-08-2008 16:38:16
Thanks! I did suspect the plate under the PTO was going to have to be removed and fluid drained. I am going to replace the cartridge filter assy for the PS trans with a modern spin-on type for easy changes and common/cheap availability. Just waiting on 2 fittings for the new housing. But My parts guy said there was the cartridge filter for the PS trans AND a spin-on for the HYD sys...a big 2 quart one I have in hand. Was this second HYD filter an option I may not have? And if so can I add it and where would it be installed? Thanks for the feedback!
