Creek Jenkins
Hello -
I"m new to the forum. I just kind of inherited a Series 1 D17. It"s in kind of rough shape, but it runs okay and everything seems to work. It has a trip bucket with single acting cylinders, a scraper blade on the back, and also came with a 7" snowblower. I picked up a 5" Ford bush hog last week. The blower has a 3 point conversion thingy as well.
The tractor sat outside for 2 years, so it has some water issues. I drained the tank, cleaned the carb and put in a carb kit. I drained the hyd oil (front plug) and put in hyd / trans oil. I drained the trans oil (back plug?) and put in 80/90 EP. Changed the engine oil and put on a new Fram C159 filter. Engine smokes a bit, but seems okay.
Biggest problem is the foot clutch is stuck. I hooked it to a stump last night and bumped the hand clutch a bit, just spun the wheels. So I put it in 3 gear and bumped the hand clutch while holding the foot clutch in. No luck, it just groaned.
Any ideas?
Any ideas?
