Company Logo (800) 853-2651 Shop Now
WD 45 flywheel
John Gottlied
08-25-2008 18:25:47
I have ne like I have never seen, It has a blall bearing in the flywheel that acts as the pilot bearing and the pressure plate only has three fingers with mounting bolts on each side of each finger. Can any one tell me what it is I have??
I also would like to know how much pre load the pressure plate should have.
Thanks in advance John
JMS/.MN
08-26-2008 13:16:04
 Re: WD 45 flywheel in reply to John Gottlied, 08-25-2008 18:25:47
WD45 did not use a pilot bearing. Most WD and earlier tractors did. WD45 had either an Auburn or a Rockford clutch. Some Rockford's had nine springs, instead of six. For details on the clutch setting- you'll find it in the AC-11 I&T manual. Three fingers are normal. Your flywheel and clutch might be from a WD.
alliswd45
08-26-2008 07:22:53
what that is, is your clutch,
pilot bearing
the pic is what you call a pressure plate,
and a clutch disc, you basic clutch and clutch kit
Today's Featured Article - Pop's Tractor of Gold - by Gary Teate. My father was a simple man but could repair just about anythin mechanical that was ever made. From the time I was a young boy growing up in Jacksonville, Florida, I would spend a considerable amount of time helping my father repair or rebuild equipment and engines, etc. on our 2 1/2 acre "spread". Pop always dreamed of having more acreage out in the country where he could retire and tinker as much as he wanted and often reminisced about his boyhood days on his grandfathers farm in Montecello, ... [Read Article]
Latest Ad: Looking for a skid for a W_power unit----also a green & yellow John Deere antifreeze gallon can. [More Ads]
Copyright © 1997-2022 Yesterday's Tractor Co.
